jo1010
- West Berkshire, uk
Pulling power: most dozers are 10 ton...but you get additional power from additional 10 ton porta powers inside the vehicle if access is ok
The approach is always to peel off layers of bodywork ie removing spot welds of panels in the damaged area and remove one section at a time to reveal underlying damaged panels - some of which can do one times be pulled out...sometimes not.
Some videos explain this better...this one had a newb trying to pull out some range rover damage - and the later vids show the pro solution...
youtube.com
Here's some side damage a non pro was repairing....
And just for fun.... this guy built his own car o liner type jig.....
Alu channels inside the sills? (Rockers in USA) I didn't even know they did this - adds another complexity. If you need to cut and shut this you'll need TIG to weld it. I don't recommend learning tig just for this one area though (learning curve is months unless you've done tig before).
Measuring? Tape.... and I used to use roofing battens to transfer measurements from one side to the other. A 1m ruler can be useful too. A proper trammel is about 200£ now so not worth it for a one off repair
Study the vids and you'll get there....one other thing some times useful - have bracketry on the dozer to allow downward pulls - the pull chains run under the bracket
And redirect pulling force downwards - in one of the vids above you see the Dozer levering itself up in the air when they tried a very optimistic pull (which was going to fail anyway for other reasons)
Range Rover Evoque Write Off Rebuild
Share your videos with friends, family and the world
