For a stationary engine running regular* fuels pretty much any flavour that's weldable. For a car/bike softer flavours like 1050 or 3103 will deform more than say a 6xxx series without splitting (in either case radiusing corners for buttwelds = better than outside corner joints) and strain harden a lot more slowly than many of the common 5xxx series (ease of shaping, fatigue** from vibration/fuel sloshing)Just out of interest what would be the correct grade of aluminium for something like this?
OEM automotive ally fuel stuff covered here http://european-aluminium.eu/wp-con...AM-Applications-Power-train-5-Fuel-System.pdf but the flavours they mention for tanks like 5754-O don't really exist as thin sheet for the likes of us; AFAIK 5754 is commonly only available as 5 bar treadplate in the H114 condition.
Personally i use 1050 or 3103 (both in H14 temper) and weld with 1050 or 1450 wire as 4043 is harder/more brittle so ideally only used for welding 6xxx series tube/machined fittings into the tank
* Blend enough ethanol in with the fuel and corrosion starts to become an issue, same deal with methanol fuels and ally. Especially with a little water in the mix as both are hygroscopic
** Granted more of an issue with aircraft but FWIW http://webcache.googleusercontent.c...blems/Problems.html+&cd=1&hl=en&ct=clnk&gl=uk
