BChild
SIP - enough with the mods!!!!
Hi,
thank you for taking the time to post......and apologies for the late reply (I've just had a minor 'op' and wasn't feeling too good )
I did try both terminals ....and had constant 'feed' from both, when I get chance I'll re-check everything....and if I cannot find the 'fault', I'll post some wiring pics ....perhaps the circuit boards are slightly different on some welders.
All the best
David
No probs with the late reply
We've definately seen different boards on SIP and definately different connection arrangements
....some how the voltage increase 3 times just by passing through a wire ???? There are no shorts and no other obvious explaination.
) However I would not expect it to be a higher voltage. With the transformer wired up with the constant feed problem I originally had, I had measured 36V DC at the wire feed motor.....so voltage was a problem before.
I have no idea why I was getting 'strange readings' or why it didn't work before (certain wire connections are exactly as before) ....but wire feed now works from the trigger....checked DC voltages at the wire feed motor ...low speed around 3V fast....22+V .Haven't had time to lay a weld ....but hopefully everything is OK. Will post whether improvement has been made, thanks again
