If you try online at an industrial supplies you can buy an "Everbuild" polyurethane sealant which is pretty much the same stuff but 1/3" of price. Its actually a bit better since they have slightly changed the formula so the whole tube dosn't go off like Sikaflex. I am a Marine Engineer and use loads of it and have a lot less wastage with the Everbuild stuff. I buy it from "fynepax industrial supplies" in Dumbarton.
Thanks for the replies lads.
So these generic PU sealants are fine to be over painted? And pretty much ch anything labelled polyurethane is OK to use?
Easing oil/ wd40 or whatever is to hand gets it off quite easily.yes it can be over painted,But,let it cure first,depending what you've put the PU on depends how long it takes to go off.
Put it straight over bare metal or over a new weld etc,over fresh paint might take longer
Oh word of warning,its messy and a b**** to get off your hands,sometimes![]()
I used to wash my hands in the Trichloroethylene tank as did everyone else^^^^^ yep
blimey the bad things we use to clean our hands
he says using petrol![]()
If it's the Sika number you need go for 221
We use loads of the stuff, It's what holds these together plus one or two rivets
Afternoon lads
So I'm just about to order some of this gear. If I get the pu40, does it bond like sikaflex? Or is it just like a bathroom sealant?
Cheers again guys
No gearbox it's direct drive then toothed beltBlimey that sounded like a bag of gravel's been dumped in the gear box when it was going up the ramp![]()
