DAPPH
as dyslexik as I'm daft
Poorly unevenly sharpened /angled cutting edges will also lend to holes wandering that's why a good centre point drill in a locked up tailstock ram is used to advance a hole for the first few mm.By angle do mean to the centre axis or just meandering? As you quiet rightly say theorectially it shouldn't happen. Drilling oversize is possible with a good size drill, unless your using a small drill and it's flexing a bit like Dynarod. They drill for oil that way. Saddam was stealing it from Kuwait (one place I haven't worked in) by drilling horizontally. That's possible. Cheap drill and not centred from the off. My cheapo Chinese drills are very much a mixed bag. Had some centre drills where the chamfer had been ground in reverse. Trying to explain to the seller was like Basil and Manuel. But not sure which one of us was Manuel in the end.
Some hadn't been hardened.....etc.
Out of a nice grey & blue windowed presentation box of 0.5 to 15 mm in 0.5mm's HSS twist drills made in Turkey & sold in the likes of B&Q big box stores four of the smaller drills had been sharpened with the web of the drills justified to one side ... to almost 1/4 of the drill diameter
As soon as I discovered the 1.5 mm drill was off I checked the rest & reground all of the badly ground drills
