Newer battery storage systems are relatively simple, you have a grid connected battery inverter that monitors incoming/outgoing via a CT clamp and sorts out what you want to achieve based on the settings you set. Or use a hybrid inverter that is both PV inverter and battery inverter rolled into one.
However, this comment makes any battery storage irrelevant.
If you are fortunate enough to have a meter that will run backwards if exporting, you have a zero cost or maintenance, profitable energy storage system connected without even doing anything. If your meter spins backwards when you export, you're effectively selling generated power at the same value it cost you to turn the meter forwards.
If that's the case, get some PV up asap and enjoy it before the meter gets changed.
If you do do it, you should probably not submit meter reads, in summer, that suggest the clock has gone backwards though.
This is brilliant! My stubborness might pay off.
Not having a battery even better.
Although, im limited as to what i can export am i not?
Which is another question, how is that export amount controlled? I still dont get that bit?
This has just moved up my list of priorities!
