Ubique
- East Midlands
Like Loctite 480?Wurth do one I use for grips on quads and motorbikes, it is like a black thick superglue.
Dan
We use Lina 88 at work but it's 'kin expensive...
Dan
Any landing you can walk away from is a good one . Just remember they have never lost one up there .yea was a bit hairy seeing as though i never had any lessons with an instructor , just jumped in it and off i wentanyone can take off and fly its the coming down thats the problem in one piece . as for the manifolds i sent off for some new ones
Cos you tuck your trouser in your long socks and don't bother with poncy cycle clips.brown trousers and bycycle clipsi dunno how i have lived so long and got away with it.
I would think that the glue is infra red or some form of heat cured with the two parts under pressure ......... a bit like vulcanizing patches on big inner tubes .This is the "weight". Not a very good pic sorry but basically it is a lump of [metal] bonded to the little block of rubber which is then bonded to the small plate it is sitting on. It has come away from this plate.
View attachment 43353 View attachment 43354
The unit then attaches to these lugs on the support arm below, and the arm bolts into the rear subframe via the 2 round (metalastic?) bushes. Then the diff is held in through the 2 holes visible (and is also supported by a bracket at the front).
Sorry about the bad pics and messy workbench.
dont ever use bison metal to rubber gluei bonded 2 rubber to metal inlet manifolds on me microlite engine , got to 300ft and the engine spitted and farted then conked out
after a scary emergency landing found the carbs had fell off and the glue gave way
character building stuff
As another poster suggested - how about fitting something that is already bonded to a plate already?Guys can anyone recommend a decent glue to bond a rubber 'weight' back onto a steel plate. It sits on my diff as (I assume) an anti vibration device. I've found some "Rema 2000" but can't see where to buy it from. Any suggestions?
