Mi chiamo Lucien sono al livello medio come saldatore a TIG qualcuno mi può spiegare come fare capire che facendo Roots pass che fondo bene i due lati poi come fare capire dosare il materiale d'apporto tanto o meno
Ringrazio in anticipo
As has been requested by a small number of members I'm happy to start a small guide as a starting point for newcomers into welding aluminium. The idea is to simply give you a starting point so your new toy can be taken from the box and dialed in without the grief of guess work or diving through...
www.mig-welding.co.uk
What thickness of material are you using that requires a root pass? I’ve only welded thin stuff, but I am sure someone will be along who has experience of thicker material. @Cheesie@Hood
Lots of variables which make lots of differences, but as a basic example using mild steel, if you start practicing on plate butt welds in the vertical position, 6-8mm thick with a 3-4mm gap, prepped to a V with a 1-2mm landing face using 2.4mm filler wire, you should be able to set the amps to whats called key hole-ing allowing you to burn away the V'd edges adding filler without blowing through melting away the V'd edge opening up a huge hole,
Once you have mastered that, you could try introducing the filler wire into the centre of the 2-4mm gap and with the correct amps you will run up the root run filling without key hole-ing filling the root run much quicker,
The next pass you must try not to burn through but have enough amps to bit into the parent material ensuring no cavities remain.
Molte variabili che fanno molte differenze, ma come esempio di base usando l'acciaio dolce, se inizi a esercitarti su saldature a piastra in posizione verticale, 6-8 mm di spessore con uno spazio di 3-4 mm, preparato per una V con una faccia di atterraggio di 1-2 mm utilizzando un filo di riempimento da 2,4 mm, dovresti essere in grado di impostare gli amplificatori su quello che viene chiamato foro chiave che ti consente di bruciare i bordi V'd aggiungendo riempitivo senza soffiare attraverso la fusione del bordo V'd aprendo un foro enorme,
Una volta che l'hai padroneggiato, potresti provare a introdurre il filo di riempimento al centro dello spazio di 2-4 mm e con gli amplificatori corretti correrai il riempimento della corsa della radice senza il foro della chiave riempiendo la corsa della radice molto più velocemente,
Il passaggio successivo devi cercare di non bruciare ma avere abbastanza amplificatori per mordere il materiale principale assicurando che non rimangano cavità.
