I bought a couple of pairs of bronze castings from @mark roberts a few years ago for the PK saws. This for the quadrant or double mitre, they are normally cast iron and usually go missing or get broken. This is what they should look like, I believe this is probably one of Mark's renovations.
This is one of the two sets of castings that I bought
Given they are not cheap, and my neighbour is a toolmaker that works at an aerospace company that has many rather large machines, I cheated and got him to machine all the major dimensions. I had a drawing of one of the two castings plus Mark posted a pair of machined castings to me so we could take dimensions. We also worked off the bed of the table saw to get the various pivot points, slots and retaining pin holes aligned so that the quadrant did what is was supposed to do. from a geometry perspective. this video shows what they should do, the quadrant appears about 4:50 in,
My neighbour did all the major milling and returned them to me, they then needed a few holes drilling and tapping, plus lots of filing around the pivot to allow the two parts to rotate around the pivot.
I don't have any parallels at the moment, they are on my Christmas list, so just used the clamps to lift them off the mill base
They are awkward shapes to drill, for the next one I had to get the "Yorkshire" parallel out
and for tapping
After that it was filing time, I used lots of sharpie to show me where I was filing to keep it square
Plus I used more Sharpie when fitting the two together, this time it showed where the two components were catching when pivoting so I coud remove just the right amount
Eventually it pivoted sufficiently so I could check if the machining was correct. We were pretty confident but decided to mill one pair at a time in case we screwed up.
The pivot, handle-clamp and pin are just temporary, not the finished article, the handle just happened to be 1/2" BSW
Two coats of epoxy primer by brush. once this has hardened I'll give it a light sanding, top coat may wait until I have the other two castings fettled
There's a bit of fettling to do, but only a little.
There are a few tweaks we will be making to the other two castings during machining, only minor.
Next step is to get on with making the pins out of 303 stainless, I'll wait for the other castings first as the pin length will depend on the final machined height.
