Repurposing old propane cylinders disaster
  1. minimutly Member
    1,486
    Pembrokeshire Wales
    Now, don't panic, no-one died, nothing went bang. I had a need to make a melting machine to melt some alloy scrap. My daughter had three old cylinders,way out of date, some rust etc. I needed 20 inch diameter by around 28 inch height, so I set to with the hose pipe and thin discs.
    Topped and tailed 2 of them, split one vertically, cut acsection out of the second to let into the other.
    This needed some porta power action, big hammer etc. Now I'm normally very good re ppe, and I did thinkI should have been wearing gloves. But the point was brought home when the ram slipped and the rolled steel cylinder sprang back, taking about an inch of the skin off my little pinky.
    Ouch I said...
    Pics of the melter to follow, it's a welded cylinder, pivot tubes and tilter welded on, waiting for bottom and top metalwork.
    Bsmith, indy4x, slim_boy_fat and 4 others like this.
  2. gaz1
    gaz1 Member
    11,309
    westyorkshire
    snigger you should have known better
    but still you pressed on knowing it :D
    metalmelt likes this.
  3. minimutly Member
    1,486
    Pembrokeshire Wales
    But I put a glove on after the first aid treatment!!
  4. brightspark
    brightspark Member
    31,669
    yarm stockton on tees
    [QUOTE="minimutly, post:.
    Ouch I said...
    how strange when I get a good belt of the electricity at work I say ohh dear me I have just got a shock :whistle::rolleyes::laughing:
    Bsmith, dobbslc, octo0072000 and 10 others like this.
  5. Parm
    Parm Oh how I’ve missed my play pen this year
    13,051
    Towcester
    is that in a Yorkshire accent?
  6. minimutly Member
    1,486
    Pembrokeshire Wales
    Yes very good. Only ever had two - one at home when I was a boy, and one when working in the milk factory. The second one made me jump back, shook me quite a bit. My apprentice, looking very concerned, asked if I was Ok?
    Yes I said, and thanks. For what? Not laughing said I, 'cos I would have....
  7. barking mat
    barking mat Barking at Pigeons
    4,602
    Brittany, The Arz Valley.
    Live and learn....
  8. doubleboost
    doubleboost Member
    3,126
    Newcastle upon Tyne England
    Image of injury needed
    roblane65, fizzy and Hopefuldave like this.
  9. brightspark
    brightspark Member
    31,669
    yup north yorks
    metalmelt and Parm like this.
  10. minimutly Member
    1,486
    Pembrokeshire Wales
    Ok, if you insist...
    Not quite ready to lift it off, but pretty sure i't's dead...
  11. Spark plug
    Spark plug Member
    3,778
    Durham, England
    by that do you mean bite the raggy bits off and carry on regardless.
    BarrieJ, dobbslc, jerrytug and 7 others like this.
  12. barking mat
    4,602
    Ouch!
  13. doubleboost
    doubleboost Member
    3,126
    Aye good one
    fizzy likes this.
  14. doubleboost
    doubleboost Member
    3,126
    This will make it feel better
    metalmelt, TomCGB, Seadog and 2 others like this.
  15. badabec
    badabec Forum Supporter
    529
    Essex UK
    Push or tease all the raggedy bits back into place then cover with a plaster. It will heal much better that way rather than cutting or biting those bits off. No Savlon, no Sudocreme. A plaster will keep it warm and damp, ideal for new skin to grow. 'Let the air get to it' was discounted in the 60s, unfortunately they never told anyone.
  16. TechnicAl
    TechnicAl Member
    8,232
    Rotherham
    Oh Ok....when you said your "little pinky" I was expecting something else....but I was worried when you mentioned photographs
  17. Lewis_RX8
    Lewis_RX8 Member
    468
    Scotland
    Had to make the photo cover me whole screen :o
    Most recent of mine was a nasty bleed on the thumb from a erm misplaced hammer strike
  18. metalmelt Member
    589
    UK
    Get one of those silver coated plasters, heal much quicker.
  19. Migmac
    Migmac Forum Supporter
    4,681
    Kintyre. Scotland
    I’ve always thought letting air at a cut was a good thing. Live and learn
    nickk likes this.
  20. Screwdriver
    Screwdriver Forum Supporter
    6,895
    UK London
    The key issue with a workshop injury is to make sure it's clean, then dress it. Remove the dressing every so often to make sure it's not festering (that's what I understand the "air drying" recommendation means) because if it's kept damp under a used plaster which is wicking away at the infection, it can be a breeding ground for infection to develop. So if I end up with a decent wound, I will change the dressing as often as possible commensurate with allowing a scab to form.
    magnet, Wany, Hopefuldave and 3 others like this.
Advertisements
