backpurge
With the handleOk you've all got me worried now! How DO I safely turn off an argon cylinder???
With the handle
I once saw a cylinder with the valve half dissembled and a 6mm ish spanner on the square key.Ok how else would you close the valve. Long noise pliers I guess....![]()
48" Stillsons should sort itOk you've all got me worried now! How DO I safely turn off an argon cylinder???
I do understand the ISO system and the backward compatibility with European and British standards. If you read my post nowhere did I mention BS.Actually it has both Brad, you can use either as the BS has been adopted as the EN.
No, actually there was no point to your claims at all.
