where does led bulbs come in to it ??If you keep loosing led bulbs then possibly you side has a problem. But this very uncommon.
generaly with surges sky tv and freeview boxes cop it 1st cant say I have ever caused a led bulb to go using an insulation tester set on 500v I have trashed a couple of sky boxes that the punter was supposed to have unplugged but didnt
We use LED in Emergency lights.
Never had any fail, some of the sites I work on often lose power, then the emergency generator kicks in.
The most common failure on those sites are the auto doors, they default to0 factory resets.
Indirect powered goes through charger and battery circuit. Plus they are made with more consideration than a 40p gu10
If set to "Non Maintained"
If set to maintained, they are direct fed.
Buy another off him via ebay then return that one as faulty for a refund. You get your welder - he gets what he deserves.
That could lead to problems if he records serial numbers.
