msmbus2000
- NI
I no the master doesn't need injectors coded, but trafic do they? Codes for injectors are just saying "aaaaaaaaaaaaaa" not a normal code as such
if the pumps out,the trigger that picks up on the front of the timing case from the drive gear will be out.i work on a very large fleet of these........
Well I can take front of van in record time now at least lol
Yep diffo soul destroying but that's life eh
line the belt up with the timing tools,remove the bung on the front of the timing cover at the injector pump gear,look up at 11 o`clock position there should be a hole in the gear,if its at 5 o`clock the timings 180 degrees out.then you have trouble.................................
Sounds like good advice and scotb has done the job before!
I am convinced that modern diesels are not reparable
I have had my fingers burned to many times
Once they are 6 years old 100 k plus they are finished
