regulator advice
  1. simon. p New Member
    9
    cheshire uk
    i have just bought a used clarke 100e. and am thinking of using hobbyweld 5. i have oxy acetelene equip which is not in use and was wondering to use the oxy reg. if so what would i need to connect up?
  2. Maker
    Maker nEw mEmBeR
    7,071
    Don't ask questions
    Just get an argon regulator, I'm pretty sure the fitting is different on an oxygen bottle so you'd need an adaptor/new bullnose (I don't think they're available), the flow reading will be wrong with a gas of a different density and, at the risk of starting an argument from another thread, the old oxygen reg is probably out of date.
    Yamhon likes this.
  3. Yamhon Member
    1,095
    Earth
    The Ultra size Hobby Weld cylinders come with a regulator already fitted, the next size down might as well; so it'll be worth checking what size you want as it might already come with a preinstalled regulator.
  4. pedrobedro
    pedrobedro Man at Matalan
    10,242
    CX Derbyshire
    My big Ar/Co2 cylinder has an oxygen regulator on it and has been in use for years, works fine just make sure it's rated for the pressure in the cylinder and that it's the correct thread.
  5. simon. p New Member
    9
    cheshire uk
    many thanks guys.
  6. simon. p New Member
    9
    cheshire uk
    just picked up a hobbyweld original. (no reg) so i was thinking of trying it with oxy reg. (the regulator in the shop £38 + vat) looked the same other than the small outlet for the pipe) plus use a flow meter (which i've seen online for £9) but then i came acros this
    https://www.ebay.co.uk/itm/Argon-CO...a=0&pg=2386202&_trksid=p2386202.c100677.m4598
    but the outlet, although purpose made for mig. seems large, similar to oxy guage. also i get the impression that the small hose is just a push fit? so would i need another adapter of could I make something up?
  7. Brad93
    Brad93 M J B Engineering
    7,388
    Essex
    Don’t use an oxygen regulator. The weight of the gases are different.
  8. pedrobedro
    10,242
    CX Derbyshire
    What difference does that make ? I've had an oxy reg on my cylinder for years and it works fine, it works on pressure not weight and the cylinder is filled to the same pressure as an oxygen cylinder.
  9. Brad93
    7,388
    Essex
    Sure use them, your choice I can’t be asked to teach people on this forum any more.
    dholdi likes this.
  10. T0rnado69
    T0rnado69 DIY nut !!
    1,682
    Basildon, Essex
    personally i would use the correct regulator for the correct job.
    that way you know for peace of mind its going to work fine and have no hiccups.
Advertisements
