Alec, can tou tell me what gas the tank is using and get the numbers off the compressor and make would be helpfull, getting the coolant at a lower temp takes more power thus not as efficient, you want to be evaporating your refrigerant at about 8*C colder if it was air and less for water.
) two expansion valves /solonoids . The lines coming from the expansion valves looked about 3/8" .
) to more or less the desired temperature 4 degrees .
