I've done exactly that not that long ago in a box section probably slightly smaller than in that vid.Cant see how you would be able to weld a plate inside a box section as on Jody video, using a conventional torch? Be interested to know how to do that sort of job without flexible neck torch?
Just to throw another one in the pot for you Matt; the Parweld range is (IMHO) a bit clumsy with the MIGsy type handles for TIG. However, Tom was posting about some new ones coming along that are apparently not as bulky. I mention because it doesn't sound long and Parweld are usually decent quality for the price. Other than the bulky handle they're a nice unit.
If you're buying a complete torch with cables/hoses then a large chunk of what you pay for is quality/flexibility of the hoses themselves i.e. dirt cheap with relatively stiff nasty hoses that may have the water passage partly blocked by a badly crimped, stiff power cable or more spendy with overbraided silicon rubber hoses and better quality/more flexible power cable in it etc. While CK are about the only ones shouting about their 'superflex' cables they aren't the only source as silicon overbraided cables have existed for eons
I haven't used a flexhead torch for years but i'm guessing that watercooled versions are still less flexible than air/gas cooled versions for the obvious reasons? As said any flex head will fatigue and break eventually if you actually flex them about to make life easier so the head itself becomes a consumable and one that (rarely) can drive you temporarily insane if they spring a leak inside rather than just fail completely
Things like flex loc or roto head fix the fatigue thing (just an extra O ring or two) and offer more anglular adjustment but in some situations will be bulkier than a regular torch of the same size due to the layout of the neck. Another variation is a ball joint which gives a bit of adjustment and a choice of heads... http://www.weldmarkuk.com/wp-content/uploads/2016/04/WTB-Ball-Joint-i-Head-Torches-2016.pdf
Personally i don't miss a flex head torch, rarely think such and such would be easier with one and on the rare occasion when i can't get at the joint with a fixed wp20 a flex neck some other posh/spendy variation on it wouldn't help as there simply isn't physically room. It's time to swap to wp24 or proper micro torch and prat about with stupidly short tungstens
Weld craft should be up there too.Guys, lots of arguing and not many recommendations.
Can we keep this on Topic please.
So far we have:
CK Flex Loc
SpeedWay 320 Flex
standard WP20F
Any other torches I should be considering?
And you won't Matt.Thanks for the info. One of the reasons for wanting something decent quality was for the flexibility of the hoses etc. It may be that with that added flexibility a flex head would not be required.
TBF I was at it for about an hour today doing inside and outside joints with a standard wp20 and didn't have any issues with positioning.
No a lathe is easier.....Ha. That's easy for you to say you are bloody good at it.
Tig welding is easier than good use of a lathe imo.
But it will be to me!
I'm not convinced.No a lathe is easier.....![]()
Your half way there machining as your having a go at threads, i agree machining is easier to learn than tig.I'm not convinced.
Gonna be a hell of a long time before I'm putting cubes in cubes.
small, light, flexible cables, and cheap.....
So am I but since buying a small farm, and being the preverbial incommer, Im growing my tight wad behaviours to fit in around hereSame requirements minus the cheap. After spending on the rig it all comes down to what you hold in your hand. I'm happy to spend the money there.
Make sure it isn't one of those horrible euro style ones... Like the 26 I gave you. The round handled ones are much better. That wp20 you have is a starparts and is about 15 yrs old, they make a good, reasonably priced product.
