thinfourth
pleb
- Stonehaven
I’d go for smaller ratchet straps as big ones will just squash the tank
ill just not go crazy when ratcheting it up, wider strap will spread the load better surely.I’d go for smaller ratchet straps as big ones will just squash the tank
So it's just sitting on the ground then?
I've never seen one tied down. I mean people might, but I've not seen it.
Even when they're 'empty' they still have a fair bit inside them, as the take off is never at the base of (modern) tanks so as not to suck sediment. It's always about an inch up, and an inch of kerosene over the area is a fair bit of weight.
Drive about and look at what other people do, and see if you can spot any others that are strapped down...
im a delivery driver and there are lots of tanks strapped down here, id say about 10% of tanks.Top of scotland so the weather is a factor and also it is an upright tank rather than a horizontal but lots of people here even strap down horizontal tanks.
Could you "squash" the eye of the bolt into an oval so that the strap hook will fit?
