Fraserb
- Scottish Borders
All, your help and advice is invaluable and I will need to do some experimenting, not least sort out my Y axis!
However, this plate is due to go on the side of a stone Clumber I need to ship and I'm running out of time (this looked so simple.......)
In the interim, is there anyone who could cut the word "Clumber" centred on a 60mm x 6 x 400 steel plate. I can supply the plate and the G-code (as I also had issues with the dxf and have had to edit at G-code level!)
Cheers
Peter
I can check to see if I've a big enough bit of 6mm, definetely have 5mm.
. Yes you can't do everything, but you should have capacity up your sleeve
