small diesels are expensive.
get the engine and gearbox out a 2.5 simely frount transit.
botch it into back of disco, connect PTO to end of tansit gearbox.
but extending the draw bar on the mower and fitting a tranny engine on there ( as already suggested) has merit as any 4 wheel drive could drag them round then imo either spray the weeds or rent the field out to a neighbourhi
we tried the mowers on next doors tractor at the end of last year, seemed to cut ok but the field is like a sports field, big and flat but l need to keep on top of it and start cutting as soon as the grass starts growing, l have used the field for hay in the past but last year we were invaded by doc's, unbelievable amount appeared by magic, l am being told by the framer next door that repeated mowing will see them off, the grass being hardy will always regrow while the weeds will try a few times and eventually give up, will need to mow almost weekly and keep it like a lawn, is this why our lawns at home dont seem to suffer with weeds/doc's ? dose it sound plausible or is he pulling my plonker here ?![]()
he wasnt using the "good" stuffdoes spraying work ?
l use to rent the field to a local farmer who had it sprayed every year to get rid of the docs, each year they were back again and in greater numbers, l always though the contractor was being clever and spraying with fertiliser to make sure he had work the following year![]()
As dai says, spray it for docks, mowing won't get rid really.
No point in cutting grass just after it grows.
spraying will cost ya about 4 quid for spraying and approxx 10 for the chemical
you WILL use more than that in diesel everytime you cut it![]()
he wasnt using the "good" stuff![]()
