Some is lost to the exhaust of course. Perhaps 4..5kw into the room.Agreed. Maybe a little over 4kW but not a lot. 0.5l of diesel contains about 5.25kWh of energy.
Not for the main warehouse. I would need an SMR for that - They are welcome to install oneThose missing roof van /vent would never see you able to get it even slightly warm Fizzy , plus it being made of uninsulated wriggly tin you'd have Swansea's biggest radiator .
Not for the main warehouse. I would need an SMR for that - They are welcome to install one![]()
You'll need a darn great tin of Germolene to heal your anal orifice up before the landlord does that judging by the poor state of the rest of the industrial estate . For as long as you are still holed it won't happen .theres no point where you are unless you move to an insulated building and then you would need other areas that are controlled with partitions and curtains up so the areas can be heatedNot for the main warehouse. I would need an SMR for that - They are welcome to install one![]()
I found the insulation (not quite there yet, but 3/4 done) of the workshop enables the bearable use of an electric convection oil-filled radiator on a timer.I don't like the idea of some random combustion device blowing air around in a confined space . . . and if it's that cold in the garage that I need one, I'd rather be inside the house doing something.
How high is the roof, and could a side exit be cut ?I would love one but roof too high for a flue and whilst I would be fine lighting it others wouldn't be!
Roof height about 9 or 10m. Very exposed to wind. Also needs to be idiot proofHow high is the roof, and could a side exit be cut ?
It's an absolute kitten to light , if you get the hang of it.....
Disrespect it, though, and it's a rather angry tiger.....
Once disrespected, it will idiot -proof idiots, believe me....Roof height about 9 or 10m. Very exposed to wind. Also needs to be idiot proof
If I move to somewhere with some nice old outbuildings for my own use I wouldn't hesitate.
You can buy about 30 of them now for the cost of an EberspacherI keep looking at these and thinking they might be a good replacement for the non working Truma gas/electric heater in the caravan we bought. Parts for that are extortionate and it takes up a lot of space. Theres already hot air pipes and vents around the caravan that one of these would hook up to and from experience of the eberspacher in my landy one of these diesel air heaters would run for quite some time on a dedicated battery.
they are fitted in most things for the air they put outI keep looking at these and thinking they might be a good replacement for the non working Truma gas/electric heater in the caravan we bought. Parts for that are extortionate and it takes up a lot of space. Theres already hot air pipes and vents around the caravan that one of these would hook up to and from experience of the eberspacher in my landy one of these diesel air heaters would run for quite some time on a dedicated battery.
Fear and pain are excellent teachers...You underestimate the average person. You'd think they'd learn....
If they are anything like as good as my ancient Webasto in performance, then I'll be well happy.I keep looking at these and thinking they might be a good replacement for the non working Truma gas/electric heater in the caravan we bought. Parts for that are extortionate and it takes up a lot of space. Theres already hot air pipes and vents around the caravan that one of these would hook up to and from experience of the eberspacher in my landy one of these diesel air heaters would run for quite some time on a dedicated battery.
Agree with all of that and matches my thoughts from the use of the D1LC i have in the 110. The pump for that is mounted on the chassis and it ticks away - can be heard when stationary but not when driving. I might go for one as a cheap solution to the non - working gas/electric Truma heater in the caravan. Think that's only 2.5-3kW actually so a 5kW air heater would be an upgrade thinking about it. The rest of the space removing the Truma would leave can be converted to a cupboard!If they are anything like as good as my ancient Webasto in performance, then I'll be well happy.
The key IMO on installation of these in a vehicle is to isolate the dosing pump very well from the bodywork.
Mine is on 2 lots of soft rubber AVM's, but I've heard variations like putting them inside a box stuffed with cotton wool, or using rubber O Rings under tension to suspend the pump.
Otherwise you get a solid "THUNK, THUNK, THUNK" as the body acts as a drum amplifier every time the pump pulses.
Heat & efficiency-wise, my Webasto is great. Sips fuel, and as @fizzy says - I've measured mine pulling 20 Amps on startup, but once burning and running without the glowplug, battery draw falls right down. Also, in a small space like a van (insulated) you don't need to run it for long periods to warm the space up.
Kero seems to burn hotter & much cleaner than diesel, so it's all I use through mine.
(I've ordered one of these at this price myself)
Buy one that claims to be 8kw. They are only 4kw. The 5kw ones are actually 2 to 3kw. But not alwaysAgree with all of that and matches my thoughts from the use of the D1LC i have in the 110. The pump for that is mounted on the chassis and it ticks away - can be heard when stationary but not when driving. I might go for one as a cheap solution to the non - working gas/electric Truma heater in the caravan. Think that's only 2.5-3kW actually so a 5kW air heater would be an upgrade thinking about it. The rest of the space removing the Truma would leave can be converted to a cupboard!
