Finally got my wire feed working! I'm a total beginner.
I'm using flux core 0.8 wire on thin sheet metal, hoping to use the 'stitching' method, but mostly I'm messing around getting used to the settings a little.
A big problem I'm having, especially with tacs, or very short runs, is at the end I get a pronounced void/crater. It can be pretty deep. Seems to consistently happen when I stop the weld.
Any idea why?
Here's some examples:
(Please excuse the big embarrassing hole!)
Welder was set to the minimum settings.
Any idea why?
) but if you do, you might as well use it as you can see what's happening more easily. Alternatively keep practising with flux core - as noted by a few people, it doesn't have to be a spattery mess. With a bit of practice you can see the weld pool well enough to be able to control it and get pretty good welds with minimal spatter. It's just a lot more difficult than using a shielding gas - but a lot cheaper and more convenient in many situations (eg outside or occasional hobby type use).
