Thrashsmith
Can anyone recommend a retailer of power file belts that last more than 30 seconds?
To suit Evolution power files FWIW.
Thanks
Thanks
Exactly what I do.I buy belts for a 4” ish wide belt sander and split them down. They have a thicker/stronger backing fabric, and seem to last ages.
Just need to remember to draw the rotation direction arrow before I split it down.
I have seen someone online do this before with a lathe, but sadly I don't own one. How are you splitting them down?I buy belts for a 4” ish wide belt sander and split them down. They have a thicker/stronger backing fabric, and seem to last ages.
That's fatal. You now need to buy a lathe!I have seen someone online do this before with a lathe, but sadly I don't own one. How are you splitting them down?
Just make sure that it isn't a good lathe, though......That's fatal. You now need to buy a lathe!
Freehand with a Stanley knife.I have seen someone online do this before with a lathe, but sadly I don't own one. How are you splitting them down?
Blunts pretty quickly. I use a wood blade in the grinder in a jig.Freehand with a Stanley knife.
Hmmm not sure how you'd do it in a lathe to be honest. Normally I just poke a Stanley knife through it to make a hole, and then tear it the rest of the wayI have seen someone online do this before with a lathe, but sadly I don't own one. How are you splitting them down?
There is one supplier who has excellent reviews etc that are supplying fake belts. I have complained and been refunded several times. I suspect they are being taken for a ride by their suppliers.Not sure what size the Evolution belts are but 3M cubitron belts are the best, long lasting and run smooth too but also pricey. Probably works out good value with the time they last and time saved fitting new belts. Milwaukee ones are good too, again smooth running but not lasting as long as 3M and not too expensive.
I’ve tried Norton belts as recommended but they’ve all snapped, bought from eBay so maybe fakes even though branded on the back.
I have had no trouble with these - but sometimes I forget and order from another supplier. You can tell the fake norton belts. They feel brittle and all the blue grit falls off before you even start using them!Same belt / supplier as me![]()
