Bullet2012
- Berks
Ah ok, can you utilise the standard roof rack/bar mounting points ? It would be better than drilling holes in the roof and then having to deal with leaks.
just an idea
just an idea
No,Ah ok, can you utilise the standard roof rack/bar mounting points ? It would be better than drilling holes in the roof and then having to deal with leaks.
just an idea
just an idea
Is this a Mercedes SprinterOn my MWB I removed the OE plastic roof rack plugs and fitted 4x m8 rivnuts down each side then used Butyl rubber tape the between the galv unistrut and body. The bolts squeeze the tape and waterproof the whole lot. I try not drill into the body unless I really have to.
I know a lot of people swear by Sikaflex but it's a pretty hash environment on a roof, I think the butyl tape might outlast any glue type adhesive.
View attachment 287624 View attachment 287625
I have had a quick web search,Yeah but it's probably very similar to the Citroen.
I'm sure there will be mounting holes for a roof rack, I'll be amazed if not.
Yes,Most Citroen/ Peugeot vans have roof mounts like this View attachment 287638View attachment 287639
So it must have roof mounts.
It 'rings a bell', because I have seen those roof rack fittings before,How
Bob
