Dcal
- Antrim Northern Ireland
Don't be expecting miracles.
It is welding and you wouldn't expect to weld steel and have an invisible repair with no further work.
Plastic is the same and you need to dress the excess plastic from the weld area.
Only photo I have to hand is of the tig welding rod holders I made and you can get a reasonably tidy joint.
This is ABS and the filler rod was cut from the same pipe
works VERY well
..... Its all a bit stretched so if I see a S/H fender on ebay cheap IL get it....Although wifey has now claimed it for playing Forman on so it might get a few more prangs! ..... Not a bad swap for 2 sheets of weld mesh.
