I did a test piece (literally) and it seemed to go fine.
Nah, it is stone cold after a wee cut like that and probably the water splashing up on the back of the cut will keep things cooler even in longer cuts.Very impressive!Do you have asbestos fingers?
Does that work? I bought a couple off amazon to put on the torch, but was worried bout it overheating the tip? Its just so that when I glance across at it I dont get flashed when it fires! Gets boring after a few timesSilicone kitchen funnel is all I can say...![]()
Not sure what I had it at, it is at the top of the aluminium slat holders so I suppose about 25mm below the top of the slats.Try your water 10mm below the top of the slats that works best for me on Steel. But I’ve not done tonnes of ali
Are you asking about mine?What is your soft sense? It’s so much more refined than the swift cut version and faster too
