dan.taylor.1
General Tinkererer
- Kendal, Cumbria
Pcl make good ones.
if your looking to plug any decent sized compressor on a 3 pin 13a plug its not even going to get off the starting point id say.what HP is the motor? I was reading on another forum that every HP uses about 5 amps at 220 volts, in that case I'd be over loading my 13 amp supply.
I have a bog standard supply and I cant change it, its a rented house.
unless im mistaken and god knows if they hashed it or not but clarke used to do a compressor that was good for 19cfm for example.You will struggle to get 19cfm on 240v. My abac is the biggest 240v they do and is only 15ish.
yep, thats what i have here, but its from a twin unit.you can get 36cfm on 240v
