For the ML7 I used the Cobolt HSS 'T' section one (from RDG?). Was excellent. But don't seem to be able to get in a larger size for the Student. So I ended up with Iscar, after disappointing results with alternatives including cheapo Chinese insert holders. If you decide to try an insert type, beware of the holders that just have a taper and no anvil. Stops the insert from splaying the holder. I thought I'd bought the 1st image and 2nd image arrived. Refunded.I need a parting off tool for my ML7. Is it worth going for the blade type with removable inserts? It seems like a costly way to go about it.
I got mine from Chronos and find they work well on my little hobbymat too, I use a 2mm x 10mm blade on a 5/16"square shankFor the ML7 I used the Cobolt HSS 'T' section one (from RDG?). Was excellent. But don't seem to be able to get in a larger size for the Student. So I ended up with Iscar, after disappointing results with alternatives including cheapo Chinese insert holders. If you decide to try an insert type, beware of the holders that just have a taper and no anvil. Stops the insert from splaying the holder. I thought I'd bought the 1st image and 2nd image arrived. Refunded.
All the more expensive holders do a similiar approach with some form of stop. Only the dirt cheap ones don't
View attachment 349693View attachment 349694View attachment 349709
That's it Chronos not RDG....eBay history didn't go back far enough.I got mine from Chronos and find they work well on my little hobbymat too, I use a 2mm x 10mm blade on a 5/16"square shank
New Clamp Type Parting Tools with Chipbreaker Blade (5% cobalt)
New Clamp Type Parting Tools with Chipbreaker Blade (5% cobalt) from Chronos, with Free UK delivery and great worldwide delivery rates. Chronos Engineering tools.www.chronos.ltd.uk
...I use a 2mm x 10mm blade on a 5/16"square shank
don't know what you mean,That is the difficulty with the blades: they are very shallow compared to their width. This increases deflection and reduces useable stickout and hence the diameter of stuff you can cut. You could roughly work on a stickout equal to the blade depth, so the cutting force goes at 45 degrees back into the holder.
Compare and contrast typical HSS blade 2mm x 10mm deep and 2mm inserted tool 2mm x 19.5mm deep (https://www.arceurotrade.co.uk/Cata...ng-Tools/ARC-NCIH-Part-Off-Blade-Tool-Holders). Since stiffness increases with the cube of depth, that is a big difference.
I don't know if there is a "proper" reason but I had to make 49 little tapered pins the other day and constantly winding the carriage back and forth then changing the tool holder to part each one off was a pain.Why is it recommended to use the parting tool on a rear tool post?
the tip wont dig in using the cutting tool upside down from the rear grit your teeth if it does cutting from the frontWhy is it recommended to use the parting tool on a rear tool post?
Also those holders for the inserts are not shouldered so all the force goes on the lower section, whereas with your setup you have the full depth of the blade.don't know what you mean,
thats 60mm diameter EN3 bar on my hobbymat, which isnt the most sturdy of lathes
The rear toolpost is something I haven't tried or have. But I can visulise the benefits. The extra rigidity comes from it being mounted directly on the cross-slide, so that also does away with the toolpost side overhang. The tool is downwards cutting, which will assist swarf removal, unless you run lathe in reverse, which is unwise on a RH screwed on chuck. The action will try to lift the rear of the saddle which is pretty tight with the gib strip. On my Colchester there is significant lift in the front of the saddle, but the locking clamp, which stops sideways movement also stops that. However the action is still a downwards force and still equates to lifting the rear of saddle.Thanks all. All i've ever used are the hss type parting tools on proper lathes. My myford came with a hss parting tool, but I haven't used it. I'm upgrading the tool post to a gib type which I got from banggood.
I'm not sure of what the motor is rated at, but i'll probably run a 2mm gtn insert. I imagine that it would have an easier time dealing with a 2mm cut.
Thanks to whoever mentioned arceuro. I was struggling to find somewhere other than china to order from for a reasonable price. Looks like I can get the whole lot together instead of having to order everything separately as well.
SLTBN Part Off Blade Tool Blocks with Blade - Arc Euro Trade
SLTBN part off tool blocks with NCIH self-locking parting blades and GTN inserts. Sizes: 6-16mm shank, blades for 2mm & 3mm GTN insertswww.arceurotrade.co.uk
And it also removes the top-slide from the equation along with any associated play.NB. Think I've just convinced myself to make one.
Good, I doubt you will regret it.
The carriage lock on my lathe (always engaged for parting - and most facing operations, too) clamps on the rear way rail. That prevents any tendency to lift.There is no cutter overhang for tool leverage problems, the cutter is as close to central, over the cross slide as I can arrange. All in all the best geometry I can provide (my toolpost is a QC variety, so cutter overhang/extension is always something to keep ‘as reduced as possible’).
Most problems with surface finish are resolved by operator adjustments. Parting is not usually considered for the finish - but the same things still apply.
On the Mk1 Student there are no tee slots on the cross-slide. There are on the saddle. Only threaded holes. I've utilised one for the suds. There are forum members who have Students. Whether any use a rear toolpost I don't know?Mine has a main bolt from top to T nut in the cross slide and another, shorter bolt through an extension to the base. Both T-nuts are in the same slot. I keep it at the back of the cross slide, but have to be careful that the cutter will reach past the centre (or less, if there is a hole through the part) before the feed screw reaces its end of travel - a disaster for something if that were to occur while under power feed!
I’m guessing the feed post is in two parts with suitable shimming between, to achieve centre height.
Mine is at centre height, for my lathe, and the cutter obviously extends perfectly in a horizontal plane, so I’ve never needed to look, check or fiddle. It just works. Sharpen the blade (about 20mm deep?), select power feed and concentrate on lubrication until the item falls off.
The only thing to sometimes check/set is that the blade is not deflected at all, if cutting deep. I sometimes widen the kerf a little, if I am not totally sure. Apart from taking those perfectly reasonable steps, parting works fine on my over 50 year-old hobby lathe.
