Thats interesting to know. Theres quite a concave curve that the 3" struggled to get into without excessively tilting it, and I was using an interface pad, so I think 3" was better suited.. but then I've not used a bigger one on panels but I was using it right up to the edges.i would never reach for a 3" pad for that , 5 or 6" with an interface pad
Thought they were bolt holes.....Spot the fisheye![]()
good on you for keeping going id have thrown the dummy out the pram and launched it by now@Onoff you dont know how many hours I've spent on this!
Anyway the trim panel was ready, atleast, and nicely primered. I exoected that to give me more problems due to PP plastic, but all was good. One last clean with meths inside my freshly vacuumed, mopped, clean tent, and on with colour.
Spot the fisheye
Other than that it sprayed perfectly. The red is much deeper and darker in person, this camera doesnt pick up reds very well..
Wipe off, light sand and start again?
@Onoff you dont know how many hours I've spent on this!![]()
One last clean with meths ...
... Spot the fisheye
It might not be silicone (but it could be) - meths can hold water that gets left behind when it evaporates. The dye in the purple stuff also gets left behind when the meths evaporates.I've not previously had issue with silicone.
Lesson learned..somone told me that meths and IPA alcohol, was near enough and worked ok. I've not previously had issue with silicone.
I was intending to buy the proper stuff however the paint shop only had 5L tins, and I already have more solvents around than I want, so at the time I got one of those from local tool station on way home.
If there any suitable alternatives that I can buy on a Sunday from local shops?
Then with P800 I dry sanded the defect back to primer and scuffed up the whole face. I gave it another wipe with meths and it all came off
Meths did not touch the 1k spray can primer I was using earlier, but seems to wet the basecoat.
I'd had enough, thinners out, wiped the trim back to epoxy. I'm not going to make any progresss today. Then wiped off all of the 1k primer from the panel back to metal.
I got the 0.8mm nozzle out and mixed up more epoxy primer and gave all the rub throughs, 3 thinned coats. I got all of them as I'd used permanent marker and big arrows to point at each!
I absoletely hate cleaning epoxy primer out of my guns. I'm also finding it seems to settle, where the paint left behind the nozzle and needle seal is very thick sludge - might explain the occasional problem I get with it not spraying well. I used a 190micron paint filter for filling gun..
Going to order a pair of smaller nozzles for the GF3 for primer duty
Its not about the money, I dont want 5L of every possible solvent taking space. The paint shop did not have anything smaller.im tight but always use panel wipe , whats the point possibly destroying a job over a few quid ?
works with synthetic paints , not so much 2kI knew a guy that used to respray refuse trucks and other commercial vehicles and he had a two ring electric hob that he kept two 5l tins of his paint sitting on, then he'd pour it in his gun and spray it while it was nice and warm, and a lovely job he made of them too.
@Turbo it was not heated but there is no issue with slightly warming the paint. Yes I weigh paint on 200g extra sensitive scales which is needed to get accurate hardener.
I am using 2k thinners. Not the best but it is not recycled gunwash.
While it may be setting in the gun, or settling out, its a pain. Hb 989. I've not got much left and its about 5 years old.
I use kitchen roll as cloths for panel wiping.
