Kram
- Sussex
I need to paint some new abs plastics for the bike. As its a nose cone and will be hit with flys it really needs a hard finish. I previously used cheap spray cans and couple years later looks like the moon.
The new abs panel is not great, the moulded holes and some other areas need to be strengthened I will probably use epoxy glue and glass fibre and take a bit of tine to prepare.
Is there any good alternative to 2k paint?
From some reading on here, looks like only clear/top coat contains the unsafe isocyanates?
Another fred mentioned that isocyantes are relatively safe to brush /roller paint. That would give a hard finish that can be polished smooth?
There was a recommendation on here for HB Body 989 epoxy Primer, saying that it can be sprayed with a nornal mask?
Or would a spray can primer be ok?
I do have a 1L tub of halfords mixed acrylic metalic blue which is correct for my bike. It is old but has not dried out, so I can use that for the colour coat.
I also have a 600ml bottle of acrylic clear so I could use that, but wont be hard coating.
I dont have an air fed mask or anywhere suitable to spray iso.
I will probably be using the spray gun included with my sgs compressor.
I also need to buy a suitable half mask, replacable filters for spraying or grinding dusts. May be difficult to get one now? I could use a recommendation what to get anyway.
I have a water trap for compressor but I should probably get one of the dessicant types.
No used ones on ebay. Slg-620 is cheap enough but listed as solvent paints only?
