brightspark
- yarm stockton on tees
u cut the end of the blade not the baseWell shorten it at the fixing point is no good for mine as the blades have a cutout groove to lock on the blade holder.
u cut the end of the blade not the base![]()
I did use my noggin, used a better machine, quality blades and a very large cast iron block - I bought a meddings scroll saw![]()
What how do manage to cut a worktop sink hole out on one of them? specially if the worktop is 8ft long.
Unless I've got early onset dementia I can't remember saying I was cutting a worktop sink 'ole![]()
Well you got it anway cos thats what windy was harping on about cutting a worktop sink hole with his wandering jiggy.
They're large, sturdy pieces of kit, aren't they.
. I've only had a little play with the big-un so far.They are that, I have a small Proxxon scroll saw that I used on the Toylander and it was great but lacked a bit of throat, the meddings fixes that. Yes, I bought that one from Scott. I've only had a little play with the big-un so far.
Fitting some type of filter on the breather pipe should stop that (re)occuring.
The legend within the Landy world - the Hi-Lift jack. Horrible things, used at Pay 'n Play sites by numpties. I've seen folk changing tyre with them and on one scary occasion saw two lads crawling about under a 90 trying to wrestle a spring back in to it's seat after it had popped out. OK if used correctly but it's a tool that has 101 ways of maiming you and only one way of safely jacking up your motor.
dad always used hi-lift to change wheels but also carried axle stand, and slid wheel under 110 as extra safety.
having that bad boy spinning round on the balancing machine this afternoon was a bit hairy.
looks like it belonged to some medival police station for obtaining the truth...what the hell is that off?
