Opinions on Cebora Arc Welder?
  1. Andy Gregg
    Andy Gregg Member
    22
    Devon
    Hi all,
    I've been after a used arc welder, and a Cebora 210 dual voltage has come up for reasonable money. I have been using my Cebora Boxer mig for odd jobs, but found that I wasn't getting enough penetration when I tried welding a bracket to my trailer.
    What's the consensus of opinion on used arc welders. Do I just need to avoid and invest in an inverter?
    Any help much appreciated!
  2. gaz1
    gaz1 Member
    10,933
    westyorkshire
    arc welders are for anything upwards of 5mm depending on your mig welder that you have
    i have the cebora 195 mig welder
    i also have 2 arc welders a sip 90 old thing and recently an oil arc welder
    inverters are ok but for me they are more of new tech wont last as long as my sip 90 arc welder
    Memmeddu likes this.
  3. Andy Gregg
    Andy Gregg Member
    22
    Devon
    Cheers gaz1. I've got the 155 which is fine for car body stuff, but I need something heavier for the bigger jobs. You reckon £55 for an old Cebora arc is ok?
  4. Munkul
    Munkul Jack of many trades, Master of none
    2,643
    Cumbria
    Yes. nothing wrong with transformer welders if they're good quality.
    Not sure if that model is AC or DC, assuming it's an AC buzzbox at worst, but that's ok... it'll be one of the better ones.
    Ideally DC for stick welding, it's just smoother and nicer IMO. And you have a wider choice of rods for positional work.
    Memmeddu and Andy Gregg like this.
  5. gaz1
    gaz1 Member
    10,933
    westyorkshire
    im a skin flint so 50 to me for something old isnt a good thing
    i would with an oil arc welder but that is not transportable you leave it in one place
    like i said i bought an oil welder weld all day with it with no cut off cool down time on it
    ive bought often enough at car boot an arc welder for 10/20.00
    Andy Gregg likes this.
  6. Pigeon_Droppings2 Member
    2,935
    london
    Stick welders are cheap as chips I think....I'd be inclined to just buy a new one and have the benefit of the warranty. I think for less than £150 you can easily get a descent new one with a 2 year warranty that is very compact and portable?
  7. Andy Gregg
    Andy Gregg Member
    22
    Devon
    Fair enough! I'll have a look around...
  8. Munkul
    2,643
    Cumbria
    If you're upping the budget that much, then you may as well get a 160 amp DC inverter. Really smooth to use, and can run up to 4mm rods which is enough for nearly anything you'd want to do.
    https://migtigarc.co.uk/xts-163--mma-inverter-arc-welder-795-p.asp Something like one of these.
    If you want to keep it budget then there's not much to actually go wrong with a good old branded AC machine like the Cebora.
    Or you could buy a chinese inverter off amazon for under £50, but they aren't exactly a quality product.
  9. Memmeddu
    Memmeddu Member
    2,741
    Italia Sardegna
    Buying today a new inverter arc welder I would like to go with this
    https://www.weldequip.com/parweld-xts-162.htm
    Because it's cheap and cellulose capable
    I didn't knew that when I bought my stamos S-MMA 250 IGBT that it's cheap "Chinese?" Welder but it's a kind of lovely one
    I bought that stamos just because being a pro series from stamos it comes with 8+8meters welding leads 25mm² it's actually copper but the insulation isn't the best rubber quality in the world maybe it can be also pvc or polyethylene .
    But after changing electrode holder , ground clamp and after almost a year of use the powercord it's a good little cheap welder
    I love it
  10. Andy Gregg
    Andy Gregg Member
    22
    Devon
    Oh ok... food for thought, I'll have a look, thanks! What's a good mid range make you might recommend?
  11. Andy Gregg
    Andy Gregg Member
    22
    Devon
    Shame you had to change a few things, but I do very little so I'll have a look, thanks!
  12. Pigeon_Droppings2 Member
    2,935
    london
  13. Andy Gregg
    Andy Gregg Member
    22
    Devon
    That'd looks pretty good, and I've got no problem spending the money for good quality gear. You also can't go wrong with such a good warranty.
    Have you found that's it's pretty much 'plug and play's, or have you had to customise it to make it perform, as seems to be the case with others?
  14. Pigeon_Droppings2 Member
    2,935
    london
    My hyundai unit I just plugged it in and dialed in the amps and was good to go....nothing needed modifying and the cables were descent on the one I got (200A model).
    I don't do alot of stick....but now and again something pops up like a broken gate that needs it as the mig isn't portable needing the bottle.
  15. Memmeddu
    Memmeddu Member
    2,741
    Italia Sardegna
    I you can afford it , you can go with a fronius transpocket 150
    But I you need to use only 7018 ,6013 and stainless rods a cheap inverter it's a great investment
    I wrote a review in this forum about my Stamos S-MMA 250 IGBT
    I paid it 140+34 Euros , and despite the problems I got with the electrode holder,the ground clamp and the power cord ,it returns the investment in less than 2 months and I'm an hobbyist ,I don't use it every day .
    I used it to repair gates, farm equipment,small heavy equipment (skid steer buckets) , build things , cut H beams using E6010 and full power
    I repeat it is a "Chinese" (made in Poland) electronic mess into a box , but it's a kind of lovely one
  16. Andy Gregg
    Andy Gregg Member
    22
    Devon
    Yep, won't be spending £1200 on a fronius. I meant a BIT more ;)
    Like you, I only need it for occasional jobs. The Hyundai might be worth a look I think!
  17. Andy Gregg
    Andy Gregg Member
    22
    Devon
    Good to know, thanks. I'm going to look at their website later on!
  18. Memmeddu
    Memmeddu Member
    2,741
    Italia Sardegna
    The fronius transpocket 150 Is something like 600 euros
    Not to much expensive considering what it is
  19. Andy Gregg
    Andy Gregg Member
    22
    Devon
    Oh. I found one on eBay and it was 1200 squids. There was a second hand one for £800!
    I'll have to have a look around...
  20. Memmeddu
    Memmeddu Member
    2,741
    Italia Sardegna
    It's not the TP150 but more likely the TP180 full optional
Advertisements
