Melvyn Best
- Cambridge
must have been one of my ex bosses car
I worked with a Polish guy that was handy with a soldering iron
Depends on the age of the vehicleeml light is a fail
l
Not if its on.Depends on the age of the vehicle
I've heard this before seems hard to believe.You have to be careful doing that on bsi equipped pugs. If you don't follow the correct procedure you can cause all sorts of mysterious electrical gremlins! (google peugeot BSI reboot)
This brings flash backs following someone who had a trailer on going quicker than I would normally and cutting up the hgvs.A year on and another MOT pass today, so 14 in a row, the MIL light has been off for a year now, all it needed was the "Italian tune up" which it got when I had to follow a customer down the motorway to a job at a speed I wouldn't normally do!.
Nope, it's a 'thing' if various attached systems are not allowed to shut down gracefully. It's been a while since I was involved in PSA stuff, 30 mins shutdown comes to mind.I've heard this before seems hard to believe.
(h) Engine MIL inoperative or indicating a malfunction | Major |
(g) Engine MIL inoperative or indicating a malfunction | Major |
Can you clarify. If a mil light is on a vehicle before these dates is it a failYou need to inspect MIL fitted to:
Kit cars, amateur built vehicles and American pickups are not required to be fitted with an engine MIL.
- petrol vehicles with 4 or more wheels, not more than 8 passenger seats in addition to the driver’s seat and first used on or after 1 July 2003
- petrol vehicles with 4 or more wheels, more than 8 passenger seats in addition to the driver’s seat and first used on or after 1 July 2008
- gas and bi-fuel vehicles with 4 or more wheels, not more than 8 passenger seats in addition to the driver’s seat and first used on or after 1 July 2008
(h) Engine MIL inoperative or indicating a malfunction Major
Engine malfunction indicator lamp (engine management light or ‘EML’)
Turn on the ignition and check that the engine malfunction indicator lamp (MIL) illuminates and then goes off. On some vehicles it will be necessary to start the engine before the MIL goes off.
You need to inspect MIL fitted to diesel vehicles with 4 or more wheels and first used on or after 1 July 2008.
(g) Engine MIL inoperative or indicating a malfunction Major
A MIL before these dates is not a testable item I would properly give a manual advisory .Can you clarify. If a mil light is on a vehicle before these dates is it a fail
Its different in Northern Ireland. The manual here states that these years are the only years required to have a mil light and the only ones you check the sequence but if a mil light is on on any vehicle it is still a major regardless of year as it showing a fault.A MIL before these dates is not a testable item I would properly give a manual advisory .
This is black and white ether not working or illuminated after those dates major fail
bouncing off the rev limiter for a few minutes
My daughter lives in NI, she brings her car home to Wales for an MOTIts different in Northern Ireland. The manual here states that these years are the only years required to have a mil light and the only ones you check the sequence but if a mil light is on on any vehicle it is still a major regardless of year as it showing a fault.
Not necessarily. For example tyre pressure light indicating a malfunction is not a fail.Over here any warning light on the dash is a fail, not just mil!
It is here on cars registered after Jan 2012 . . . hence having to find some flippin new sensors for the other halfs car . . .Not necessarily. For example tyre pressure light indicating a malfunction is not a fail.
