Erie Fred
- Erie, Pa USofA
You don't say....Some on here could boil a kettle on their heads - thinking too hard, if you ask me.
A 4-wire wound ALTERNATOR, not output. You've got the wrong end of the stick.4 wires ... how many you want?
Neutral L1 L2 L3 ,4 wires
PE isn't even required most of the times with a power generator.
Because they are practically ground insulated.
If you connect the neutral to the ground now you need PE , because voltage can go across a phase and ground passing through you
@8ob brought down a gennie his mate had sold to me. Big enough to run our house off one of its phases... Wasn't that dear but mine does come in at over a tonne I think. Dad had one as well which sounds amazing being an air cooled Deutz but as it was on wheels and he couldn't handle the weight of mine to move it around.Spot on. I'd love to find an affordable good one (1ph, most are 3ph and only 4-wire so not reconfigurable) for my folks place. Being able to fire up a solid lump like that, with practical certainty that it'd run as long as you needed it to without issue, economically - well worth providing one with some house room in an outbuilding.
The 1500rpm heavy old Deutz oil & air-cooled Deutz engines are solid, tough bits of kit. I recall where I worked decades back we got to see the occasional 6-pot Deutz - a build quality that made you feel one would run forever. I think Deutz parts might make you wince more than Lister bits though.@8ob brought down a gennie his mate had sold to me. Big enough to run our house off one of its phases... Wasn't that dear but mine does come in at over a tonne I think. Dad had one as well which sounds amazing being an air cooled Deutz but as it was on wheels and he couldn't handle the weight of mine to move it around.
They've got a single-tooth ratchet that prevents that, but not uncommon for that tooth to be grimed in place and any ratchet action is non-functional.I don't think it happens with the twin cylinder one's but the single cylinder will sometimes kick back when starting and run backwards. That means the crank handle is being driven at 1500rpm until it flies off the shaft. Time to run when it happens.
If the engine starts backwards that ratchet is being drivenThey've got a single-tooth ratchet that prevents that, but not uncommon for that tooth to be grimed in place and any ratchet action is non-functional.
Lister introduced an "anti-kickback starting mechanism" for the hand start - an option to meet CE Certification for sale/use in the EU...... but that was on the T Series motors and I think sometime after Yr 2000.They've got a single-tooth ratchet that prevents that, but not uncommon for that tooth to be grimed in place and any ratchet action is non-functional.
I've been told the smaller S & T Series (1, 2 & 3 cyl) engines were popular for narrowboats, while slightly bigger boats might go for the H Series (HA & the larger HR in 2, 3, 4 & 6 cyl) another cracking heavy strong engine.We have a lister twin on a work boat, it spins a good sized prop and certainly motors along nicely, no one has any idea how old it is.
