Pete busby
New Member
- UK cornwall
First of. Hi there found this forumwhen looking for problems with my old but trusty Oxford 161.
Had this for years and it stopped working yesterday..
[/URL][/IMG] I turned it on. And went to use it but the wire feed wouldn't spool. the gas solenoid opened.and it had "arc." Then it popped the fuse in the plug. So I changed it. And had a look at the wire spool motor as this had stuck once before. But this seems fine. Removing the side panel it looked inside it looked very dusty! So I blow it out with my airline. Plugged it all back In... and nothing! The fan turned on, only a rely click with pressing the trigger! ! Had a little route around and cleaned up some contacts and went to turn it on again but this time it started buzzing like it would if I was trying to weld with it even though the trigger wasn't pressed! ! And blow the fuse again! I've disconnected the wire motor thinking it might still be that but once turned on it still made the buzzing noise so I quickly turned it of again.
Struggling now to think what it might be.. looking at the inside wiring and pcb board it all looks very basic? ? So there can't be to much wrong with it?? I would like to get it working again as it's served me well and it has sentimental value to!
Can you still get a PCB boards for it? Or is there such a thing as a universal board you can fit?
Long first post I know but hopefully someone can help.
) the box drawn to represent the transformer on the pcb should have been bigger to include the Live pin going into the tranny!
first better picture of the wiring as requested.. then pulled the covers of the relays and found the top one burnt and I'm gussing stuck open!! So would cause the problems I'm having?? So can I get a relay replacement for it ? Or a similar one that will do the job. And I guess the question is why did it over heat in the first place? ?
