mylesdw
Transferred from the 'Show us your lathe' thread because it is a bit off-topic.
I had asked how to get my Colchester lathe to do a nice smooth cut.
Can you explain the bit about reversing the power feed a bit more please? Just interested to know the reasoning behind it.
Myles theres a few reasons why that possibly happened.
Could be harder spots in the material but should still cut.
More likely as have the same is the cross slide wear. Try tensioning or locking gib strip solid and take a few thou off, report back.
When its on power feed have a look to see if the bar is pushing out or rubbing then suddenly digs in. Don't change anything send it back down in reverse and make sure cross slide hand wheel don't revolve, if cuts its play in the slides and or the lead screw.
