How about Helium for less unsprung weight?
I just know you're joking there but in any case it's unsprung mass you need to reduce i.e. the momentum of rotating/reciprocating parts. Using a lighter gas would technically achieve this but the mass saved would be incredibly small.
trouble is you just know some big race team somewhere has tried it to see about how well it works![]()
Note this last set of Nitrogen filled tyres on my Sedona ...same brand as before (fitted 9300 miles ago ) are not showing the same wear as the standard air filled ones . I'm almost up to 70K and would have been needing a new front set by now,
What pressures do you use in your Sedona? When we bought ours I found the steering to be heavy & vague, checked the tyre pressures and they were correct according to the plate (somewhere in the 30psi-range).
I have a works van that is almost identical in size & weight to the Sedona, uses the exact same size tyres with the same ply rating but the working pressures were in the 50's and 60's. I pumped the Sedona tyres up to 50psi and the steering & handling were totally transformed. Been like that now for 3 years, no handling issues wet, dry or whatever and no funny wear problems with the tyres but the steering is much lighter and more positive.
Filled with air though, not nitrogen![]()
