addjunkie
- Northumberland. Reet oot in the sticks
Nah, pellet prices are climbing in line with timber.pellet might be worth considering if tou have the space
it used to be with the installer so if im wrong i will except that im wrong however noted that theres 2 options on baxi site as ive looked on there
reference here
https://forums.moneysavingexpert.com/discussion/5768399/baxi-warranty-reduced-from-10-years-to-5
my mate fitted one in his house after 2 years it jacked in and they had stopped making them so he changed to an oil boilerpellet might be worth considering if tou have the space
Conventional non combi boiler with a 3.8kW solar pv system - you will have free hot water in the summer (and on clear winter days), free sunday roasts, washing etc, plus the option (when the designers get their act together) of connecting a modern controllable storage heater or two. You will need a shower pump though.
Modern conventional with a well insulated tank is on a par with combi - factor in the pv as well and you'll wonder why you even asked.
Gas or oil its up to you - oil is generally cheaper, plus you can do your own maintenance if you're that way inclined.
Friend of mine in a bungalow draws hot air from a vent above the woodburner, through the loft and over to the furthest bedroom. Helps circulate heat and is pretty effective in a bungalow. Just a thought.
Pretty good option imo. You can get older type storage heaters to charge up in excess PV easily enough. Annoying to have to put up with them but easier if it's free to run.
Something I've often wondered, especially appropriate in a small, well insulated bungalow, is how the economics of going all electric, with hot wire ufh would be. Sensibly controlled and linked to one of the super off peak tarriffs, plus as much PV as you can throw at it, installation and maintenance costs would be pretty low. Running costs in winter would be high, but offset with a decent woodburner.
A full house of electric underfloor heating would be horrendously expensive
It costs 3 to 5 times more to heat something with electric than gas or oil
I get that but I think that there might be a point at which (in terms of amount of kWh required) the extra cost per unit is cancelled out by the lower cost of installation/maintenance.
So yes, obviously a leaky mansion won't be heated with resistive heaters, but at some point, in terms of kWh requirement, it might make sense?
A small, well insulated bungalow, with a woodburner might be approaching that point...? Haven't done a back if the envelope calc but suspect that it would depend a lot on if you could do the bulk of winter heating with wood.
I've done full calculations, heat loss, U values, expected usage etc and it's honestly not worth it.
If, and it's a big if, battery storage becomes viable with solar PV that may change but at the minute it's no
Heat pumps are the (expensive) answer in a properly insulated property, full wet ufh and solar PV to top the thermal store up. Budget £15k for a small bungalow for a basic system
I had a similar dilema a few years ago. Being all electric in our village and no mains gas for 4/5 miles.
Next choices came down to either oil or LPG, nowhere really for a proper oil tank install without it looking hideous, couldnt be doing with clattering gas cylinders about and having to keep ordering...siting a boiler was a pain too, so I went all electric.
Hot water via an unvented cylinder, supplying 2 bathrooms. Shower is reasonable.
Heating, is a wet radiator system just like any other boiler type setup, but uses a Heatrae Sadia Amptec boiler . The usual radiators with TRVs/timers ec.
The Upstairs bathroom has electric UFH and independent elec towel rail. Kitchen has plinth heater.
Suplementary log burner in the living room, which only really gets lit for a cosy evening now and then.
Its been in 2 years now, no issues, no maintainence. Keeps the house warm.
Its a 4 bed detached bungalow of reasonable dimensions (with loft conversion)
Holy thread resurrection Batman...I had a similar dilema a few years ago. Being all electric in our village and no mains gas for 4/5 miles.
but, could you give a rough idea what your electric bills are in the winter? I’m in the same dilema you were, no mains gas to our village, and after tentative inquiries I have been advised that fitting a buried bulk lpg tank is not viable unless I use more than 20 x 47 kg bottles a year, as it costs around £3k+ for the install.If you have a suitable system it keeps the installation cost down, you will need a new style very very insulated water tank. We used engenera for our system, can recommend them as suppliers and installers.Holy thread resurrection Batman...but, could you give a rough idea what your electric bills are in the winter? I’m in the same dilema you were, no mains gas to our village, and after tentative inquiries I have been advised that fitting a buried bulk lpg tank is not viable unless I use more than 20 x 47 kg bottles a year, as it costs around £3k+ for the install.
However, I don’t want to be stuck changing those bottles out and humping and heaving every two weeks every winter, as I approach the Autumn of my days....
Electric would seem a simple clean alternative, as we already have a fairly modern central heating system in place, with the boiler taking up valuable real estate on the wall in my garage. Mine is a simple 30 year old, 2 bed bungalow.
