- UK
That's the thrust washer for the thrust bearing...
https://www.ebay.co.uk/itm/KOYO-AS1...481370?hash=item1ccd999f5a:g:IyMAAOSwuUlcmlTc
I'm so rubbish at ebay!
Thank you
I also posted a link to the race in last post in case yours has been damaged running over a broken thrust washerI'm so rubbish at ebay!
Thank you![]()
Cross-slide are different, they're ball type thrust rather than roller. Also cheap in Koyo brand, about £12ea SKF. Can post link in morning if needed.The races seemed ok, but for what they cost I have bought a couple of spares.
Same bearings in the cross slide?, or larger?
That would be great if poss. I've not taken it apart yet.
When I refurbished mine I found that it would pop out and disengage when it had a brand new boot fitted to it, (it had the spring fitted as well)
what I done was leave it in the engaged position with something holding it up in place while the lathe was not in use for a few days and that seemed to stop and didn’t have the issue again
thanks
Marc
