Luke
- Whitchurch, Shropshire
a 415V inverter only changes the Hz of a 415V supply
not true. voltage too.
It will maintain the correct V/f ratio for the motor (as entered as motor data in the inverter).
Hello MK,
there are 1ph to 3ph 415v output inverters available, see here:-
www.drivesdirect.co.uk/Products/Digital_Inverters240_415.htm
Alec
It's got a twin pulley, so have you considered running two single phase motors to it, one to each groove?
How about a small petrol or diesel engine, you can get them for a couple of hundred new, cheaper off fleabay. Makes it portable which is always useful.
two motors would probably fight each other
Right the mud is clearing (slightly).
So a Dual voltage motor, got that one.
If an inverter input is 220v and output 220 (3ph) that'll do the business?
Like this is in the states and isn't big enough but am I reading this correctly? It's a single to 3ph inverter without transformer. Making it suitable for dual voltage motors!
Think there's an SIP or Sealey compressor about with 2, 3HP single phase motors. They must be on a timed start or one has an overun clutch. It's big money though £8-900 as I remember.
Yes you're right both motors power seperate pumps on the model I was thinking off.You're not confusing it with one with two pumps on the same receiver, (like Clarke do) are you?
What about
