gaz1
- westyorkshire
now that youve done a good bit of milling on the lathe what do you reckon to it
was it easy enough, however time is also a factor with doing it that way
would you now advise to do it in the lathe
as a suggestion here 3" box section or round pipe cut into 2"x2 drill and use a bolt on both slot the piece that your milling through both of them one at a time and clamp up using the bolts
3" due to extra size been used if need be
