gavuk
artful-bodger
- Wilts
Tux ,stick with 3/8 or 10mm bore it was most likely Amit oiler or regulator ,i removed quick connecters as these reduce the bore size and run direct from resevoir,it has made all the difference,an a cheap sealey gun i thought was weak,now can use on wheel nuts ok....if you already have 1/4" hose remove as many restrictions as possible and try it,before buying too much,,,,Gav
