If the gear on the spindle is the wrong type this will just shread the gears on the gear thats bu**red
they shouldnt be a tight fit they should be a bit of play all round and run freelyThe gears are definitely a tight fit, struggling to rotate the cluster by hand!
who supplied them . and can they shed any light on itI'm at a loss! There's no way to adjust the gears at all and aside from a manufacturing faul I'm not sure what else could cause it
MMMmmmm interesting!I'd have thought it wasn't the gears? ie its done the same thing as the previous gear set that came on it.
My guess is the two gears have been manufactured to the wrong size or tolerance.
I thought it was you that said it had happened with the previous gears the same thing. But it was Daniel. So when did you get the lathe and has it ever run for you??Well that fills me with confidence ukracer! What you thinking
Ok thats the answer I was after...so its possibly bad gears.I thought it was you that said it had happened with the previous gears the same thing. But it was Daniel. So when did you get the lathe and has it ever run for you??
