Dear good afternoon friends, I am writing for help, I hope it is possible, I recently bought a Kempotig 250 AC / DC I love it is a monster my daughter baptized as Godzilla, everything seems to work well but I have the problem that there is no gas, I thought it could be selenoid since it was intervened (loose screws) replace it with another one of a kemppi 2800 mastertig that is working but I still have no gas output, medium voltage with tester at the output of the connectors and it is 14 volts. but the selenoid that had installed indicates that it operates with 24 Volts DC, the one that I put of my other kemppi 2800 also indicates that it operates with 24 Volts. DC. The query is if that solenoid is 24 volts. DC is the right one?
The reading of 14 Volts. in the connection terminals is fine ?? or it is too low, I assume that the selenoid will never work with 14 volts. then they should be 24 so that this works well.
Attentive to your comments, and greetings.
Torch is ok, switch operate ok.
