Colin Barron
I purchased a Murex AC/DC 201is, listed on Facebook as not working. It arrived, i plugged it in, turned it on, the fans moved a bit and the mcb tripped (not earth fault). I checked the 13amp plug fusewhich was ok, tightened the plug terminals slightly and replaced back. Removed the top and side covers, reset the mcb, turned it back on. Fans on, panel on and panel appears to adjust ok.
Very strange sequence of events i was all set to test capacitors.
The welder came as a bare unit so i now need to buy a torch kit and earth cable. I will order a new replacement panel battery.
