Other Daniel
- France, Charente
In which case I would suggest that a couple of reasonably fit blokesGood point - yes they are. They're stone steps.
would simply lift and carry it to where you want it.
There was a similar stone table in several of the houses I lived in when at Bradford Uni.
We assumed they were sacrifical alters. I assume in these enlightened times you can appease the gods outside?
That would be the easiest and simplest option, but the last thing I want is anyone getting hurt or injured. I was thinking of fabricating a larger, stronger version of a plasterboard carrier (see below) to make carrying the slab a bit easier on the hands and arms.In which case I would suggest that a couple of reasonably fit blokes
Im another that would just heft up up the stairs.
No planks etc cos then you can just lift one step at a time, resting the slab on a step and just balancing it, one step at a time to prevent fatigue, slips, drops
I like that idea, but there will be scarcely enough room for one burly bloke and the slab in the stairway - it's only about 650mm wide (just over 2 feet in old money).Oh yeah.... get one of those webbing lifting slings with a loop on each end.
You can get 1-metre & 2-metre ones.
Slip the sling under the slab when it's on-end... this gives each lifter either side a solid "handle' at a comfortable height to lift with - it'd make manhandling thr slab up the steps way easier
You might have to get longer slings and have one guy heaving from above, and the other lifting from below.... but the basic method should still work.... as long as both blokes stick with itI like that idea, but there will be scarcely enough room for one burly bloke and the slab in the stairway - it's only about 650mm wide (just over 2 feet in old money).
Always wondered what it was, we had one exactly as Mango describes at the last house I rented in Sheffield. What's this about blood boilers? My friend said she had a safe in her basement, I had a look and it was clearly some kind of old wood burner.Not quite sacrificial alters but definitely used to chop up meat, usually in houses pre 1850. Around 1860 houses started having covenants to stop people having blood boilers in the cellar so the meat prep was moved out of the cellar
As for moving the slab, I'd stand it on it's end, walk it to the stairs and lump it up one step at a time by myself, two people would just get in each other's way I think. Only problem is if you slip it'll crush you, so make sure H&S isn't watching.![]()
You're always gonna have problems lifting a body in one piece. Apparently the best thing to do is cut the corpse into six pieces. Then I hear the best thing to do is feed them to pigs...weighs less than a dead body so yeah no worries![]()
I find the best donk fuel is “bet you can’t move x to y!”A decent "Donk" would put that slab under his arm and run up those stairs with it.
Bob
