Not forgettingthere is 3 people with space intent
You'd only need a sixth of it, shirley.How you landing the ISS on the moon Gaz? Just a tiny small flaw I’ve seen in your plan, but I’m sure you’ve got it worked out.
whilst the moon does have gravity its alot less than earths we can still use rockets or air to land it on the moonHow you landing the ISS on the moon Gaz? Just a tiny small flaw I’ve seen in your plan, but I’m sure you’ve got it worked out.
I think I read somewhere it would take more fuel than all the missions flown so far to the space station, in order to get it to the moon.@daleyd touch on the subject. Exactly what do you believe would be used to get 450tonnes of space station out of earth's gravity well. It's not as simple as calling an Uber for it.
What would be required does not exist and likely will not for some (many) years.
If we just move the earth to the left a bit, the moon will come with it due to gravity, but because the space station is in space it'll stay in the same place. But once the earth and moon have moved, the space station will now be closer to the moon than before. Just don't mix up your left and right or you'll make the situation worse.Exactly what do you believe would be used to get 450tonnes of space station out of earth's gravity well. It's not as simple as calling an Uber for it.
the alternative is a higher orbit or burn it upI think I read somewhere it would take more fuel than all the missions flown so far to the space station, in order to get it to the moon.
Get comfy , this could be funDon't start that bollards again.
