rcx132
Philip
- London, UK
Could you link me this video? Please! It would be very worthy for me, as I said, I don´t have idea about wether the lathe is OK or not.
Thank you
Thank you
I can't see why not.I have 5 liters of hidraulic oil HM 68 (Is ISO68). Is it suitable?
any motor oil, Think some of the importers and dealers recomend Mobil 1 which is a fully synthetic, mines got Lucasoil assembly lube because it was the first bottle that came to hand , its very sticky and not terribly cheap guess ill fill the can with Asda 15/40 semi synth ...being Scottish and all.Another question. I have read that a good lubricant is way oil ISO68. I have 5 liters of hidraulic oil HM 68 (Is ISO68). Is it suitable?
And I´m thinking about buying a quick change tool post, but I´m not sure what is its utility. Is it really usefull?
I think that all the Chinese lathes like this are very similar (there are slight design differences between the main manufacturers). Buying from a good importer will hopefully give you some back-up in the case of a fundamental problem (like the cross-slide not being square to the bed!), and may help ensure that the machine isn't too bad.
For what it's worth, I bought one last year, and it has kept me entertained through the C19 restrictions. They definitely have their limitations, and might need some remedial work straight out of the box, but I think mine is capable of reasonably accurate work with a little care. (±0.01mm). Anything over ~75mm diameter is a bit of a struggle.
I went with a brushless motor version, and have been happy with it - I haven't used the older version, but don't seem to have had some of the stalling problems reported with the DC motor versions, so would recommend going the same way if you can.
Unless you have the space for a second hand, full sized lathe, I don't think there is anything else at this price. If you want better quality, then it will cost a lot more.
If you just want to "play around" (nothing wrong with that!), and don't have the space or money for anything else, then go for it - "any lathe is better than no lathe".
Mine made these bits:
(Which turned into this: )
I always think Optima21, & also now the chap above, make a perfect case to back up any discussion regarding what's required of a lathe. When you see what they're able to create on the machines they own, saying big & solid is necessary isn't so. Any machine can work wonders in the correct hands.
Thanks for your answers
Thw WEISS WBL 180. I think is the same than a Warco 180.
The weiss has brushless motor, tampered bearings and metal gears. I don´t have idea abput how to check if is properly adjusted, so I bought this one. 1.113€ (Including shippings).
Thank you
Thank youVery nicely done, you wouldn't have a link to the drawings would you?
If you've still got the apron off there's a simple mod that may be worth doing now. When I got a minilathe a few years ago it was ok except the apron gears were exposed at the back so swarf got in making the traversing action jumpy. All it needs is a thin bit of ally plate hacksawed and filed to shape and screwed to the back of the apron casting to shield it.
What about the quick change tool post? I'm not sure about whether is sn important accessory. Someone mentione it, but why is so important?
I'm going to make a table for the late. I'm thinking in a 6mm sheet of mild steel, but it would better to do it whit a thick table of wood? Or a combination of steel and wood iver the steel?
...tailstock is fractionally high...
Hollow section is much stiffer than the same amount of metal in a solid piece.I´m not sure why do you use a hollow steel section.
