unless the shaft is hardned, the splines will last 5 minutes with the power transmission of anything but pushbike pedals
Now you have me perplexed @outofthefire
Thats because shes better looking than me. That was a great forum, shame its almost died.I was beatamax on britchopper, for some reason im facebook friends with your good lady not you
Not entirely true, a surprising amount of half shaft splines I've rubbed a file on have been quite soft.
They will be off the shelf sprockets. So shaft will be made to fit sprockets
Easy job on a horizontal mill, bit of a faf with vertical
if you lay too much weld on you could overheat the oil seal behind.
most halfshafts are made of en19 i believe easy to machine then hardened
