3 paper rounds, Saturday work in a pet shop, that included welding up angle iron frames for fish tanks, he wheeled the fish tanks out onto the pavement every day,Your parents must have been generous on the pocket money front![]()
No lick of paint for the gear box? You tightwad!View attachment 478748 ready to install into the chassis, maybe tomorrow, maybe not......
Yes, you can see where I cut away the A tunnel and have a modified section of a narrow B tunnel ready to bolt in over the hole, in 1973 I made a tunnel out of chicken wire and fiberglass mat but the B section is a great fit and will be stronger.Did you have to modify the tunnel to fit around the overdrive?
Ive a few air filter catalogues but cant check until the morningHas anyone got an old, 1970-1980's WIX filter catalogue , I fitted paper air filters inside the MGA housings 50 years ago and they are due for a change, they have WIX A70 on them but I have no idea of application, I seem th remember they were an odd vehicle in 1974-5 when I pulled them off a shelf in Chingford car spares .............
I am doing this with my Wolseley 1500, but fitting the later four synchro gearbox and overdrive, which is physically bigger. All I need is a MGB narrow tunnel to cover it, as its a lot easier than shaping something to fit, but they are like unicorn horns, and holy grails to find at a sensible price.Yes, you can see where I cut away the A tunnel and have a modified section of a narrow B tunnel ready to bolt in over the hole, in 1973 I made a tunnel out of chicken wire and fiberglass mat but the B section is a great fit and will be stronger.
I found mine on ebay, something around £100, they are in demand because a race MGB needs a narrow tunnel to be pre 66,I am doing this with my Wolseley 1500, but fitting the later four synchro gearbox and overdrive, which is physically bigger. All I need is a MGB narrow tunnel to cover it, as its a lot easier than shaping something to fit, but they are like unicorn horns, and holy grails to find at a sensible price.
Sounds a possibility, I measured mine at something like 45mm high (but a bit squashed, 80mm bore and 135 od but has some slack,Crosses over to ACDelco PB8, PC117, PC182 & PC35, Crosslands 916 which seem to fit Ford Classic/Consul, MGB V8, Hillman Avenger/Hunter 1.2/1.3/1.5/1.6 from 1970-76
Dimensions 60mm Height, 144mm OD and 88mm ID
