RobIsaacson
Hi All,
Not moved onto the chassis yet but practice, practice, pactice means I should be there shortly.
I need to rebuild along the edge of the box section so have some 2mm sheet which needs to be bent to form the angle, from underneath and up the side of the box if you understand?
How can I bend 2mm to a 90 degree angle without a press?
Should I cut a groove down the back to fold along and then run a bead to join it back up securely?
If anybody has been here before, your experience would be appreciated.
Many thanks
Rob
Many thanks
Rob
